A bit of boat improvement...
Posted: Fri Jul 27, 2007 6:30 pm
by Gus
Got it done a little while ago. Made it out of scrap teak I had lying around. Need to varnish or oil, and sand the edges, but not tonite :)
Gus
Posted: Sat Jul 28, 2007 1:33 pm
by Wag4513
Gus:
I have thought about adding a step also. However I want to place it so it bridges the gap at the top. Also I am going to drill a hole for a pin so the step will stay in place, but can be removed.
I was wondering why you placed the step wher you did.
Jim
Posted: Sat Jul 28, 2007 2:07 pm
by Gus
its the angle of the camera, it looks like its too far forward, but looking fro above, it goes all the way to the border of the companionway. I put it there because I was stepping in the cushions to get in or out of the cabin. I'll try to take another picture tonite.
Gus
p/s And that's also the spot I use to store my cooler.
Posted: Sat Jul 28, 2007 2:21 pm
by Wag4513
I don't have the bulkhead you have there in front of the shoes. Someone removed it. Gives me a place to put boat hook and whisker poles. However, I think I need something to help support the bridge deck.
Posted: Sat Jul 28, 2007 3:45 pm
Nothing like taking a seemingly useless piece of wood and creating something useful out of it.
The area behind the shoes is closed in on mine but it appears to have been fiberglassed in. I like the idea of removable access to the area so someones hard (not pretty) work is probably going to be removed.
Posted: Sat Jul 28, 2007 5:07 pm
by Gus
Wag4513 wrote:I don't have the bulkhead you have there in front of the shoes. Someone removed it. Gives me a place to put boat hook and whisker poles. However, I think I need something to help support the bridge deck.
Yeah, that bulkhead supports the cockpit, I wouldn't remove it. My plan it's to fiberglass a piece of marine plywood just aft of the bulkhead so it can act as a dam in case I get a leak thru the rudder post.
Posted: Sun Jul 29, 2007 12:22 pm
by Gus
Couple more pictures of the step project
Gus
Posted: Mon Jul 30, 2007 4:57 am
by slane1124
if possible, can you show some pictures of the inside of the compartments, so that i can see how you anchored the step on the inside? Thanks,
Posted: Mon Jul 30, 2007 6:45 am
by Gus
Hi, for the starboard side, I used three thick screws with finishing caps. I pre-drilled the holes. For the port side, I just used 3 10-24 bolts with fender washers. I might use some epoxy just to make sure the wood isn't going anywhere.
Gus
