T-26 Hull construction / upkeep
Posted: Mon Apr 19, 2021 7:32 am
1981 T-26 Courser w/ swing keel
I'm planning steps to take for this hull. Blisters were treated by prior owner two years ago.
I'll wash the whole boat first, smooth sand the hull to ready it for a coat of ablative paint. If that sanding reveals any blisters, I'll treat those first.
You can see there are a few problem areas showing on the very bottom of the keel. They may have been previously treated, or are in need of attention now.
I’m also wondering what core/lamination methods were used on the Hull, Keel, Topsides, Deck ?
I’ve found a bit of exposed foam core inside the cabin area around the interior of the windows, needing a resin/fiberglass layer. I wonder if this foam material was used throughout the boat ?
As for the hull especially, was that also a foam/fiberglass laminate or wood/fiberglass ?
Was concrete used for ballast ?
Did they use epoxy resin? polyester resin ? Vinyl resin ? For any repairs, I'm thinking I will use epoxy resin.
Thank you for any insights.
