The C26 head compartment.
Posted: Mon Jun 13, 2022 12:33 am
by Gary w/C26 & LS13
I’m wondering, has anyone ever used their head compartment for a shower. In my boat the bulkheads are clad with Formica. I don’t think it would hurt anything to wet them but I’m hesitant to try it.
Re: The C26 head compartment.
Posted: Mon Jun 13, 2022 5:19 am
by brigadoon
Gary,
Others have looked at doing that before, the consensus was you would be putting water in an area that has exposed wood. I believe the base of the wood compression post for the mast would be exposed to water in that area, if that’s the case it’s not a good idea, you might install a small sealed catch basin under the floor with a pump to drain overboard. Try useing the search function, maybe you can find a solution. I use a hand shower in the cockpit.
