DOES ANY ONE KNOW WHERE TO FIND PORTLIGHTS TO MATCH THE ONES ON THE C-26 I WOULD LIKE TO ADD ONE ON EACH SIDE IN THE V BIRTH I WOULD LIKE TO PUT A OPENING PORT IN THE HEAD .ANY SCRAPED BOATS LAYING AROUND TO ROB PARTS OFF OF WOULD BE NICE FOR THE V BIRTH
THANKS STEVE
PORTLIGHTS
good luck I have searched many many places and did not find deadlights that were very close to the size that is in the hull of the boat. The cockpit deadlights are a bit smaller so you might get lucky. I ended up making my own from milled PVC. They worked out great but unless you have access to a GNC mill the machine costs will make them to expensive.
Check in the sailing forum I posted a link to a place that makes windows that are close to the correct size. They were around 125 each.
- STEVE ROYER
