Well how's it lookin.......
Posted: Tue Mar 18, 2008 5:38 am
More pics of some of the work done and my Sunfish here
http://www.byershome.net/_Boat/Boat.htm
Posted: Tue Mar 18, 2008 6:18 am
Looks really good, esp. compared to the original pics !
Nice work
Posted: Tue Mar 18, 2008 6:47 am
by ronc98
Looks nice!
Love the shine!
what kind of paint did you use?
Posted: Tue Mar 18, 2008 11:25 am
by Gus
wow! great job, looking good! Couple of questions... do you think the boom will clear the wheel? And the keel brackets, shouldn't the bolts heads be flush or countersunk in the side of the keel?
Gus
p/s: I was looking at my picture, and I think your boom will clear the wheel.
Posted: Tue Mar 18, 2008 12:21 pm
The paint on the bottom is Interlux VC Performance and the topside red is Interlux Brightside.
The deck has not been painted yet but I want to sail it a couple of times and make sure everything is where it works best for me before I put time into a paint job up there.
The bolts were supposed to be recessed however there is nearly 1" of extra space. The heads don't stick out very far and I put washers on both sides to hold the keel off the heads of the bolts leaving the plate it's full thickness. I tried to reason why they needed to be countersunk and could not come up with anything.
I stepped the mast this afternoon and the wheel is low enough however I will have to turn it around as it was originally because it interferes with the main sheet.
Posted: Tue Mar 18, 2008 7:00 pm
by Gus
Cool idea using washers! One thing I will do if I EVER drop another keel again, is to install big plastic washers so the keel wont bang against the hull all night long. Your boat its really looking good.
Gus
Posted: Wed Mar 19, 2008 11:39 am
by Bhacurly
WOW!
I really like the colors, very nice!
I'm confused about the washers on the keel bolts, did you put something else down there to keep the keel from sliding over against the bracket bolt heads? Here's what I did anyway, and was wondering if you did something similiar...
http://naturalbornflyerz.com/chrysler_2 ... icts-1.htm
Billy
Posted: Wed Mar 19, 2008 11:52 am
I used stainless fender washers but I did consider something similar to what you did, I just did not have anything the right thickness. I also epoxied a piece of 1/2" hard rubber to the inside front edge of the trunk where it appeared the keel had banged against it a few times during lowering and done some cosmetic damage. If I come across the right material I may try something similar to what you have.
