list to starboard
Posted: Sat Apr 12, 2008 4:10 pm
by gmeddock
my '77 c22 has about a 5 degree list to starboard while in the water. it seems i remember reading somewhere that it is possible for the flotation below the seat/berth on the starboard side can be soaked with water, which might explain this.
i have checked the weight distribution, and that is not the problem.
any ideas or suggestions?
Posted: Sat Apr 12, 2008 8:13 pm
by Gus
oh memories... I had that problem. It went away when I removed the galley, and installed the battery in the port lazarette. The slide off galley weights a ton. My boat has small holes drilled all along the base of the starboard settee, in case water gets in.
