Splash Day
Posted: Sat May 24, 2008 1:17 pm
by FranS
Just finished working our way through a two page check list and are ready to splash tommorrow
Posted: Sat May 24, 2008 6:34 pm
Fair Winds, then !
Posted: Sun May 25, 2008 6:05 pm
by FranS
Splash day was a great success. We travelled about an hour from the storage site to launch site. The mast went up with a minimun of problems. We still have a slight issue with the mast swinging as we got it about 3/4's of the way up, even with using the rasing bridle system. Took about 2 hours to get the mast upright, rigged and sails bent on. The launch itself was a breeze. We even got to sail. It was dead calm all day, but about 30 minutes after we put her in, the wind started to pick up, wound up blowing about 12-15 and she sailed like a dream. It was a long, but great start to the season.
Posted: Sun May 25, 2008 6:14 pm
by ronc98
Congrates.
They do sail amazingly.
Posted: Tue May 27, 2008 4:42 am
That sounds amazingly familiar. I have a new trick with the bridle system that minimizes the swing, I just have not got a chance to post it yet. Basically it involves adding a PVC support to keep the middle part of the brindle attached to the rail tight at the proper height. The pivot point needs to remain up at the height of the base of the mast or the length of the bridle supports will not be correct length in one position or the other. I also took EE's advice and use chain.
Posted: Tue May 27, 2008 8:54 am
by slane1124
after reading your story, i'm starting to get excited about putting the Sea-Shell-E back in the water. getting closer.... hope my experience goes as well!!
Posted: Tue May 27, 2008 11:40 am
by FranS
Banshi,
Would you have a picture of the bridle configuration you described?
Posted: Tue May 27, 2008 12:50 pm
I'll try to get that up tonight.
Posted: Tue May 27, 2008 1:55 pm
by FranS
Posted: Tue May 27, 2008 4:10 pm
Here are some pictures of the lower part, I'll be getting some of the rest when I step it later this week.
http://www.byershome.net/_Boat/Chrysler ... ridlel.htm
