Missing Gooseneck Piece On C22
Posted: Tue Mar 31, 2009 4:47 pm
by Carl_IN_TX
I would like to ask a favor. I am missing a small part that goes in the gooseneck assembly. The boom has a clevis, and the mast also has a clevis, and apparently there is a small metal block that goes in between. I am missing the small metal block part.
I just got the mast up and found that the part was missing. Is there a place to buy one of these? If not I will try to make one somehow. If anyone has a good idea of where to buy one i would appreciate it.
PS: The mast raising bridles did the trick. The mast went up smooth and controlled. I used the jib halyard to attach to the top of the gin pole and made up 1/8 inch cables for the other parts. Instead of a winch I used a pair of double blocks and line to pull it up from the front. Thanks to Scott for the photos on how to do it.
Carl
Posted: Tue Mar 31, 2009 11:47 pm
UNfortuantely it is passed my bed time so I can't remember where I got mine but they are indeed available. If you do not have an answer by tomorrow evening, I'll dig it up for ya.
Posted: Wed Apr 01, 2009 12:56 pm
The goose neck and toggle page:
Click here
to go to RIGRITE.COM If memory serves, this is where I bought a gooseneck and toggle for Lady Di. Make sure you get the correct toggle for your needs!
Hope this helps!
PS: Glad your bridles worked for you! I have found them extremely usefull!!
Toggle - Thats What It's Called!!
Posted: Wed Apr 01, 2009 5:48 pm
by Carl_IN_TX
Thanks Scott, It is the toggle I am missing. After looking at the RigRite site I think it is part number K-1993 that fits my C22.
Carl
Posted: Wed Apr 01, 2009 6:34 pm
Glad to help!
