Overhaul... double mainsheet anyone?
Due to the state of neglect this c26 has seen over the years most of the running rigging is missing. It will be some time before my overhaul gets to the mast and boom, but one question has come to mind. Has anyone on this forum had dealings with a double mainsheet as illustrated on Avocet's web page a 1979 Chrysler 26. From what I've read about it, it sounds like a happy medium between a single mainsheet and a more expensive traveler system.
Chrysler 26 1980
Chrysler 26 1980
double mainsheet
I know this question may come as a no brainer to those with true sailing experience, but us novice...I as their chief would like to hear pros and cons on this system.
Chrysler 26 1980
Chrysler 26 1980
Guillaume C.
I dont like this system, when I want to release main sheet I want it to be as simple as possible.
My C26 has a small traveler on the upper cockpit floot, just in front of the entrance to cabin. I liked the setup as it is close to hands when seated to make adjustements, release sheet or to brake the boom by hand when jibing (in moderate wind only, stronger I do it by sheet)
The traveler is pretty small and not that much usefull, it could be central and be fine, you just play more with the boom vang
I also heard opinion of people who like the double mainsheet system so... up to you!
frankyd
double main sheet
Since no one else is responding let me throw my hat in the ring. I think you have described it well as a compromise in performance between a single sheet and a traveler. It is much cheaper than a traveler and the traveler on my 26' obstructs some degree of your forward view. I feel like the traveler gives more control of the boom particularly during tacks.
Frank
Frank
As stated, the double main sheet means having to release two lines if you have to really dump wind from the main.
It will also require a lot more fiddling when tacking than a traveler.
I don't care for travelers that get in the way of the companionway, just as a convenience thing.
So for us, the stock mainsheet and boom vang is the best setup.
Guillaume C.
double mainsheet
Thanks for the contriburions; others feel free to chime in.
Chrysler 26 1980
Chrysler 26 1980
This is only a personal preference if I need to get the boom in closer to windward I will bring the vang from mast bail to windward toe rail.
double mainsheet
It sounds like a double mainsheet system has not won over to many people. Having no mainsheet or boom vang at all at this point, I'll try Tom and Cathy's stock idea. A stock boom vang I can find, but I have yet to find a stock mainsheet. If I find I'll need to build one from scrach what parts will I need?
Chrysler 26 1980
Chrysler 26 1980
Terrence,
Stock mainsheet is single block, double block, and single block with becket.
Pic is here
http://chryslersailing.lizards.net/imag ... nual08.jpg
Pic is here
