A couple of stock mainsheet questions?
hp18carr
Post by hp18carr »
One... how long of a line is needed with the three blocks? Two... I've found loose screws on both of the raised sections on both sides of the main hatch where two of the blocks will be secured. If each raised section like the mast step is mainly wood could I get by with just using longer screws for a tighter hold (I'm sure these are not planned weak points.) This being the case would it be best to drill completely through and use bolts with a backing plate from the inside? :?
Chrysler 26 1980
Manuals say 35' for both jib and main sheets. I went with that on EE and found it plenty.
I think I'd go ahead and thru bolt in case there was softness due to the loose screws letting water in the block...
hp18carr
Post by hp18carr »
Thanks... reading the manual what a novel idea. :oops:
Chrysler 26 1980
Well, I didn't mean it like that ! :wink:
Actually if you can dig that bit of info out of the parts list page, you've done more than read the manual, you've obsessed over it like me !
hp18carr
Post by hp18carr »
No a fence taken... it was my feeble attempt at a joke. :lol:
Chrysler 26 1980
lecker68
Post by lecker68 »
I allso devoured the parts manual as well.
hp18carr wrote:what a novel idea. :oops:
Ohhh, I totally missed it, but then again I'm slow on puns sometimes. Was once in a study where they gave me 10 puns and I missed them all. Yes, it's true, they expected better results, at least several puns should have gotten thru my thick head, however....no pun in ten did. 8)
Mario G
Post by Mario G »
Oh with the whit you C-26 guys have ,I think I should own a pirateer.
lecker68
Post by lecker68 »
oh no Mario when I get into something I am like a Pit Bull for info. you have to excuse me. I feel I have to know everything as I feel I don't know enough. Glad to have you as a 26er, nothing against any other models I am learning some of their build and handling as well.
"when you stop learning you are not living"
sailbob2
Post by sailbob2 »
My rule is if it don't work "read" the instructions, if it still don't work "follow" them. - yuk, yuk, yuk!
lecker68
Post by lecker68 »
Ah but if it don't work then you read the instructions then aren't they "corrections"? I read that a while back and I am guilty too of not reading the instructions at times then when I do I feel silly.
