Kick-up rudder
- sauerleigh
Kick-up rudder
Does anyone know how the rudders were constructed? Looks like two molded halves bonded together. Filled with foam? Seems too light to be plywood core.
1978 Chrysler 26 "Maudie Kay"
It's better late than never
- gregcrawford
- sauerleigh
Say you must be driving a C26 !sauerleigh wrote:Thanks gregcrawford
I sanded off most of the bottom paint and it looks like the rudder had a fight with the prop and lost.
I spent a lot of time and effort repairing some gouges in the sides of EE's blade, although I just sealed a missing chunk from the back of it.
Docked one day, pulled up the rudder, tied her off and was walking down the dock wondering what that funny noise was...I'd left the outboard idling in gear, and they were fighting again....
When I still had the Sailor 280, I found that a small trim adjustment to the motor let the raised rudder clear the motor, just barely. The new trim actually made it more vertical instead of tucking under a bit.
- sauerleigh
I am trying to remove the rudder post. I removed the tiller pivot but below it there is a collar with three screws, in from the side. I removed the screws and put some penetrating oil around collar but it doesn't want to budge.
Am I on the right track with this?
Rudder
I have yet to remove my collar to remove the rest of my rudder system; my trailer does not give me enough clearance. Spray it down real good and let it sit an hour or two, maybe even over night. I had to do the same thing for my top part... a wood or rubber mallet also comes in handy. Sorry if I'm preaching to the choir, but it worked for me on the top part... no reason it should not work on the collar.
Chrysler 26 1980
Chrysler 26 1980
I have two of the top pieces, the collar and the tiller... unfortunately that's all I got witht he boat. Two questions:
1) One of the top pieces may be for a different boat. It is very slightly smaller and has a bolt running through the center of the hole from front to back. If anyone knows what it goes to and needs it - I got one.
2) Nice picture Terrance! I noticed a black something under the ring. What is that so I can find or try and make one.
Paul
Paul
Tranquil Chaos
Rudder
Paul
I take it you are sailing a c26, what you are seeing is part of the upper rudder cup bearing... black from years of dirt. There is a twin bearing at the bottom. Go to E.E's web page he has a nice breakdown of his removed rudder. If you can post some photos of what you have, I'm a firm believer that a picture is worth a 1000 words. Good luck in your endeavors.
Chrysler 26 1980
Chrysler 26 1980
- sauerleigh
I had to make a puller to get the locking collar off, right up to the end of the tube. I think someone may have used a bit of Loctite around the collar. I was able to lower the tongue on my trailer enough to get the height I needed to remove the tube. The side plates had cracked at some time, just below the rudder tube, stick weld repair, and the starboard plate is badly warped, looks like a job for a torch. The fiberglass tube just above the bottom bearing surface had cracked at some time, looks like they just tried to use some silicon to seal around the hose, this will need to be repaired.
I'm planning an upgrade to the rudder pivot area and a method to adjust the rudder post bushings without needing to pull up on the rudder tube and pushing down on the collar.
Photos at http://www.flickr.com/photos/93952888@N ... 885035070/
Your fortitude must be sterner than most, it seems no matter what stumbling block your Chrysler throws your way, you just fabricate a new gizmo and carry on. I'm looking forward to seeing how you will get your boat high enough off its trailer to lower the swing keel and perhaps pull the two halves of the shoe and swing keel bolt. What you are doing is no relatively simple overhaul, but more of a total rebuild.
Chrysler 26 1980
Chrysler 26 1980
That crack looks very familiar - have a look here
http://my.att.net/p/s/community.dll?ep= ... 294266&ck=
