Believer's restoration
- LeatherneckPA
Iron Mike - Semper Fidelis
1978 C-22: Believer
1978 C-22: Believer
sharps4590
skyking
- LeatherneckPA
Believe it or not, I was so intent upon getting Believer tied down and trailerable that I didn't even go inside of her at the marina. Yesterday was my first real look inside of her. I have to say that to my inexperienced eye she really doesn't need a great deal of work to make her sailable. Pretty can come later, since she'll be "dry-docked" in the driveway any time I choose to work on her. All of her ropes and lines will need to be replaced before she goes sailing.
Inside was in a mild state of disarray. The PO and I had both chosen to just throw things in there to get them stowed, he for storage and I for travel. Nobody needs to see that.
This was my first look at what Banshi was talking about when he said the keel could not be raised due to broken gear. I figure if I replace that shackle I should have lift capability back in the keel winch.
I am guessing here, but I believe this is the keel pin. If so, looks solid enough for this season and I can worry about repairing/replacing that in the fall.
And last but not least for this post, the tiller looks in pretty rough shape, badly checked and cracked. Aaah, woodworking. I can start with something familiar to me. I'm envisioning a nicely laminated tiller, perhaps oak and teak so I can get that nice laminated look. But again, I don't believe it is bad enough to keep me off the water this season.
There is one piece that must be replaced before I can contemplate wetting her down. One of the short ends of the backstay is broken and needs to be replaced. As time goes on I will probably replace all of the standing rigging as well.
1978 C-22: Believer
1978 C-22: Believer
Others can feel free to chime in, but that keel pin does not look original. Once you have cleared away the growth try to get underneath and shine a light up to check out the condition of the keel pin plates. No water in this area is a good sign, but we never had any leaks in ours but we heard from the new owner that when he took them out they were practicaly distingrated.
I'm with Fran.
Just for giggles, check the keel pin brackets.
Here is a link to the repair of mine. Poke through the photos and you will find nice shots of mine before and after. The before shots are hard to see what is going on however when you see the after shots it becomes clear then go back and look at the before again. Also are shots of my brackets after removel of the plates.
http://www.captainscottsailing.com/gall ... KeelRepair
- LeatherneckPA
FYI The upper fitting is the locking bolt for the keel, looks like they just sealed it up. Mine was nothing but rust and I removed it. Also the plywood backing in this area was rotted on mine you should check it out as well. No water is good and I have to tell you I was surprised not to see any when we opened her up. Here are some pics of what mine looked like and the repairs as additional reference for you. The keel brackets are on the second page just hit the next at the bottom.
http://www.byershome.net/_Boat/Keel/Keel.htm
- Chrysler20%26
