I'm thinking of replacing the three old mainsheet blocks. Two Harken singles one with beckett, the third block being a double. Should I just reinstall more Harken blocks or has someone found others they prefer. Also are these small range or mid range blocks? Thanks.
Chrysler 26 1980
Question # 101 mainsheet blocks.
Harkens are good, but so are Ronstans, and everyone I know who's used Garhauer seems impressed.
Are the current Harkens causing problems, or are you just ready for something new?
I'm assuming you aren't going to install a traveler. Before Windward's traveler, I moved the single/becket to port side, added a second bail aft of the current one and move the port side single there, then installed a large, switchable ratchet fiddle block on starboard. That gave me a 6:1 purchase, which is actually much appreciated in a stiff breeze, and the ratchet made it much easier to trim in heavy air. Don't undersize. Carbo 57s are maybe right.
If you don't have a traveler, you want to be able to vang sheet. I cascaded my vang to get an 8:1, then led it back so that I could cleat & uncleat from the cockpit.
Jeff
s/v Windward
1978 C-26 #481
http://www.lizards.net
http://www.sv-windward.com
s/v Windward
1978 C-26 #481
Jeff
The Harkens are not giving me a problem per say... just old and worn. With my c26 certain to be on the hard for a good long while, I've a mind to replace old with new where I can. I don't for see myself sailing my c26 nearly as hard as you sail Windward, but the setup you had with the blocks before you went to a traveler sounds intriguing. If by chance you have photo of this old setup please post.
Chrysler 26 1980
Chrysler 26 1980
Mario G
