In case someone else runs into this problem with a new or recent 6hp Tohatsu 4 stroke outboard, here is the problem and solution.  It ran perfect for a few weeks then it started running rough and would not idle. The  short answer is that the pilot jet was plugged with flakes of black paint! After cleaning the pilot jet the outboard runs smooth and idles perfect. I guess the paint was somehow from the manufacture of the outboard.
The carb is really easy to work on and clean.
I keep marine stabil in my fuel also.
							Tohatsu Outboard Fixed
				Carl_IN_TX
78 C22 "Trekker"
I just bought a new 8HP in June and haven't had any problems.  I replaced the battery cable it came with with one that reaches the battery compartment and love that push-button start!
Are you talking about where the water shoots out, or the intake?
1991 Capri 26 "Mari Sol"
Tohatsu idle revisit...........
I tried this and mine still does not idle correctly but I finally found a forum post where a outboard mechanic recommended drilling out a welsh plug. I was apprehensive to say the least but after some more research I found out this welsh plug covers an air mixture adjustment screw that the US government doesn't want you fooling around with less you melt the glaciers and kill all the polar bears. Realizing there would be no damage to the motor other than voiding the warranty I drilled it with a bit about half it's size it popped out and low and behold an adjustment screw it is. You can see this in the parts list which is where I realized the plug was nothing more than a tamper prevention device. I will let you know how this works when I get a chance to run it and try to get the idle right.
Aside from this idle issue this motor runs smooth and efficient but the poor idle makes shifting gears rough.
