box of new ss parts
old and corroded, was thinking of removing and re plating, but new ss is less expensive.
I was thinking the same thing, the first task is getting the bases installed - new tubes and life lines and perhaps netting is for later...LeatherneckPA wrote:I had the idea of installing backing plates also. But my reason was a little different. I was thinking that if I used SS fittings and stanchions with backing plates I might be able to bring them up to a 36" height so that they might actually serve some purpose. With a little netting strung between them they would serve to keep my Airedale on board, and maybe even my grandson.
Alan, you are too funny, I'll have a dram in your honor tonight!Alanhod wrote:A collective... OOOH, aaaahhhh, was heard across the forum. A universal tiny pang of jealousy was experienced by all who beheld the gems neseled in packing peanuts. And a Yea Baby! was uttered.
Very nicely done, and they are not even installed yet. Cant wait to see those photos with them installed.
Nice! I'm planning on leaving the height alone, I have always viewed these as "indicators of where the boat ends" and not guard rails. That's the first thing I tell anyone who I sail with that doesn't know anything about boats!LeatherneckPA wrote:OK, how about swapping the tube out with solid SS bar?
Too funny Mariner! I assumed they were there to help assure you hit the water closer to head-first, rather than feet-first.I have always viewed these as "indicators of where the boat ends" and not guard rails.
So here is my million dollar question, as you can see the deck is not flat or smooth as the base of the stanchion is. So what is the best way to create a full contact surface, without permanently "bedding" the bases? I was thinking of getting some type of rubber or gasket material and cutting to shape, so when compressed it would create a solid base? Any thoughts on how best to install these, other than goop on the caulking? Thanks.
LeatherneckPA wrote:I thought 5200 was forever!!?Alanhod wrote:Hmm, how about a silicone gasket? You cover the bottom of the stanchion in 3m 5200, stick it to the deck and screw it in place.
Keeping the water out of the core is actually quite easy. You need to over drill the holes, tape the bottom and fill them solid with epoxy. Once cured you then drill the proper diameter hole, the deck core is then never exposed, you just need to "shudder" caulk to keep any water from entering the inside of the boat. There is a good demonstration with diagrams in a recent good old boat, if memory serves.sauerleigh wrote:LeatherneckPA, Solid bar would be stronger to point, but there is just so much 1" diameter SS stock, tube or solid can take.
I would agree with tgentry. My biggest concern is sealing around the fasteners, and keeping water out of the deck core material.
Mark-mcrandall wrote:Hey John K-
Thanks a bunch for posting that link on butyl tape. Very good post! I'm getting ready to pull all my hardware and reseat, and that's the stuff I'm gonna use, includinf chamfering the holes. Great info!
So I went online and dug around looking for some tape at a reasonable cost, as per our unwritten charter.I have a box of 12 rolls of 3/4 by 1/8 by 50 feet on it's way for $60.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0344821823
Good tip, John. I'll keep it in the cool basement.From John: I found it imperative to keep the tape refrigerated right up until it is time to cut it and apply it.
Hey Mariner, I have the same question: What's the preferred epoxy for the hardware seating? Please, any and all answers/suggestions welcome!From Mariner: Any particular brand that people have had success with?
Jeff- Do you let the unthickened epoxy fully cure before adding the thickened stuff to fill the void?From Jeff: Paint the core with unthickened epoxy to get a good seal
Fill with thickened epoxy
