So, a few weeks ago, I cut open the settee to start removing saturated foam that was causing my boat to list. Thought that if I took the downhill foam out, the water would just drain into the opening and allow the remaining foam to dry out. No such luck!
Here's a shot of what i started with today. Note the dry glass on the inside hull wall. The foam looks and feels very dry:
Once I start removing foam, here comes the water. So bazaar! It's like cutting into an overripe watermellon! As soon as you violate a section, the water just starts seaping out of that section. Note the wet glass under the portion I just removed and the water flowing along the bottom of the opening (right hand side.) Keep in mind, this has been open for weeks. This stuff just holds on to water!
So I pulled out a 2-3 foot section and went back and pulled out the remaining portions of foam from under the settee top (left side, in photo.)
At the end of the day, a good amount cleared out:
Yes Sir, yes Sir! Three bags full! I didn't weigh them but these bags were easily at max weigh holding capacity. 75 lbs here, if there's an ounce. Hope they don't break before the garbageman gets them into the truck!
Hopefully tomorrow sees the job finished, fingers crossed the weather holds!
So if yer boat lists, this is what yer up against. But like was stated by another, look at all the extra storage!
Cheers!
