Not a good day on Easystreet
Yesterday winds predicted to be between 5 and 10 mph so though it would good day to try out the 150 head sail since we have never used it before. So off to the lake we went. Putt on the 150 and motored out past all the house boats. Wind blowing 15 mph and higher, to much wind for me and the 150. So tock off the 150 and put on the 110, started to raze the jib and the halyard was hung up at the top of mast, worked with it for about 10 minutes and finely got it free, then raised the sail to find out I did not attach the tack so had to lower the sail a little and attach it. Back to the cockpit and got my feet tangled up in the jib sheet. Sailed around for a few hours and ready to head back in lower the sails and started the motor. It ran for about 10 seconds and died could not get it started, tried for about 30 min. Finley gave up and called the marina to get a tow back into out slip. Back in the slip still could not get the motor to start. Came back home and had to have a couple of cold ones to try and forget about the day.
1979 C-26
Easy Street
~~~_/)~~~
1979 C-26
Easy Street
~~~_/)~~~
I have to agree with Banshi!!!!!!!Banshi wrote:The worst days on my boat are still better than my best days at work..........................
I don't know, sometimes a bad day sneaks in on the sailing fun. Then you look back on it a year or two later and it was really a good day in bad day clothing. At least my 1 bad sailing day did. Okay the first half of that day for me was most EXCELLENT, that last half of the day was ugly bad and lasted for over a month and cost me $2500 to make right. YIKES
Hang in there, there is always a better day sailing ahead, Always!
THanks
THanks
Went out to the lake this morning to see if I could get the motor to start. To make a long story short, the fuel line was kinked. Straiten the line, pumped the ball on the fuel line to get fuel to the motor. Turned the key and the motor started Wright up. Moral of the story, make sure your fuel line is not kinked.
1979 C-26
Easy Street
~~~_/)~~~
1979 C-26
Easy Street
~~~_/)~~~
That's why it's "Easy Street!!"
WOW! in sailing magazine.. they have reports of peoples sailing problems and what they did right and wrong... it is almost always a small simple thing that creates a big problem.... recently a guy literally crashed a 42 foot swan into a bulkhead ( well he was planning on doing it but ran aground right before the hit) because he could not get it into reverse. It turns out the trans linkage just popped loose!
C-26, Fixed Keel # 343
