Rudder question
Rudder question
Post by Paul »
I've been going by the plans to make a new rudder for my C-22. It shows 7/8 holes going side to side and then holes coming down into those. I'm guessing this second set of holes is smaller than 7/8 otherwise there is nothing to keep the rope from pulling through. Could someone confirm this?
http://s814.photobucket.com/albums/zz65 ... denverite/
Tranquil Chaos
Chrysler20%26
Post by Chrysler20%26 »
The second hole is 1/2 inch, the rope goes into it. Then pull it through the 7/8 hole an put a not in the rope, an pull it tite agenst the 1/2 inch hole. The not stops the rope from pulling through, I made a lup in the rope, so the same rope is used for up- rudder & down- rudder. An I filed the 7/8 hole in with Bondo. an paint
Post by Paul »
Thanks! I don't know if that note can be added to our manual section or not. That's where I found the plans.
Happy sailing!
Tranquil Chaos
Hi Paul,
If you wwould be kind enough to create a word document or PDF or such with explicit details and photos in the document ( not linked elsewhere ) I can add it to the document section for future reference!!!
I'm trying desparately to not link to other sites in the document section only because it becomes a parasitic network bandwidth draw on the other site. If we host them here then we do not have to worry another site might change or go away.
Thanks!!
Post by Paul »
I may be misunderstanding you, Scott. The drawing of the rudder is already on our site at:
Documentation, Chrysler, 22' Sandpiper (spelled wrongly), Specifications, Rudder drawing.
If you need it, I have it saved as a word document and can add the hole sizes using text boxes and then pm it to you.
Tranquil Chaos
Yes, updated/added info in the manual would be great!
Oh My! I did misspell that! Sunpiper is then name of a 42' ketch I spent time on as a teenager! I hope I'm not loosing my mind! LOL!
I'll get the spelling fixed also over the weekend!
Thanks for the catch!
Chrysler20%26
When it comes to Misspelling, I think the prize ( if any ) shuld go to me. I allso type with one finger.
Post by Paul »
Yea, well the reason I never played piano is becasue with 88 keys and only 10 fingers I was hopelessly outnumbered! :lol:
Turns out I have to scan in the rudder again because I can't save it to a document from the foum. I'll do that and add some text boxes with the hole dimensions we talked about and send it over.
Have a great Saturday!
Tranquil Chaos
