I found this approach at a local sailboat marina. I'll probably not be taking this approach
Hang it all - Anchor storage
I own an anchor, probably need another but I'm only on small lakes and will rarely use it. My question is how you stow your anchors to be ready for use.
http://i814.photobucket.com/albums/zz65 ... proach.jpg
Tranquil Chaos
In all fairness, this is a small lake. The shoreline in the background is the "other side". No currents to deal with. One of my concerns is that the hanging spool of rode will be pulled forward as slack is taken out. There is really nothing I can see to stop this movement.
But my agenda is to have a discussion so I can figure out how to fasten mine to the front of Tranquil Chaos.
Paul
Paul
Tranquil Chaos
Paul
Sorry for missing the mark, but with luck my C26 has an anchor locker at the bow adequate for line and chain, but the anchor itself most likely will need to be affixed to the bow railing in some fashion. West Marine for one has an assortment of rail-mount anchor brackets. As too what to do with the line and chain without a locker... that's one bridge I've not needed to cross. I'm sure however there are a number on this forum who has. Below is a work in progress photo of my bow.
Chrysler 26' 1980
Chrysler 26' 1980
- johnjax292
I have a fluke style anchor with the same type of hooks for mounting. I have a plastic covered chain and my anchor line runs through a anchor line fitting. My line sits in the opening at the head of the berthing. Overall it does the job, but some issues:
1) the mounts have let my anchor fall in rough seas. I use a stainless steel carabiner to lock the chain into the toe rail. If the anchor falls, it normally rides in the water until I can go to the bow and retrive it.
2) I also have tied the anchor mounts to prevent the anchor from falling.
I am currently all broken down waiting to coordinate with my boat mover. (No trailer) I will try to take a picture before I cover it for the winter.
John
s/v Gatta Nostra
1977 C22
s/v Gatta Nostra
1977 C22
Paul a friend of mine had an anchor like that and it is good and bad in some respects you can move over the anchor and shackle will move up near the flukes and pull it out easy but on the other hand we were anchored in Croton bay 3 days a breeze out of the south then a blow out of the north and the anchor came out as it was designed but his boat blew into a State swimming area and on the beach after the blow was done I pulled my anchor and towed him out.
I installed an anchor roller on Windward's bow and built a rode locker in the forepeak, but that might be more trouble than you're looking to go to.
My stern hook is a Danforth knock-off that lives in a pushpit-mounted anchor bracket. I made a bag out of Sunbrella to hold the rode, and it is hung off the stern rail as well. Before the roller/locker in the bow, I used a similar arrangement there when I sailed Windward on the coast.
Jeff
s/v Windward
1978 C-26 #481
http://www.lizards.net
http://www.sv-windward.com
s/v Windward
1978 C-26 #481
- clair hofmann
On the Mcgregor forum several owners have attached 6 or 8" PVC pipe to their bow pulpit stancions. They drop the shank of the anchor into the pipe then feed the chain in. The rode stores in a bag hanging from the rail.
Using this method, you can have a a different style anchor on each side for different bottom conditons.
Clair, I used to have just such a "potato cannon" device hose clamped to Windward's pulpit, and it worked great for the 16# claw anchor! And here I thought I was uniquely clever. In rough water or knock-down heavy air, the prudent move was to lash, or at least clip in, the anchor. Only downside was the occasional "It's the Clampetts!" comment, but threatening to turn the potato cannon toward the commenter usually quelled it. Then I'd share the rheumatis' medicine with 'em, just to be sure we ended up friends
Jeff
s/v Windward
1978 C-26 #481
s/v Windward
1978 C-26 #481
Clair --
Tried to PM you, but both messages languish in my outbox, seemingly unsent. PM me a "real" e-mail addy?
Jeff
s/v Windward
1978 C-26 #481
s/v Windward
1978 C-26 #481
