Trailer tongue jack missing crank
Hey all, I have what appears to be an original trailer for the Chrysler 22'er. It appears to be in fabulous shaope however I am missing the crank for the tongue jack.
Does anyone out there have a photo of the crank for an original C22 trailer? I'd like to replace my crank before I have to replace the entire jack. No big deal, just figured it would be cool tohave the original working!
Otherwise I'll just replace it!
mcrandall
Post by mcrandall »
Scott-
Not sure if this is OEM, but it looks like the right vintage. Best pictures I have, scrapped the old jack when I replaced it.
Bhacurly
Post by Bhacurly »
I couldnt find any before picts of mine...
I replaced it with a jack from Big R, a farm an ranch supply. Wasnt much $ at all an an easy fix...
OK GUys, I'll pony up and get a new jack for my trailer! LOL!
Capt. Bondo
Post by Capt. Bondo »
The PO mounted a flip up model on my trailer and I like it.
Once it's off the ground you just flip it out of the way.
Only draw back is that it need to be mounted on the outside frame rail so it tends to twist the frame a little.
Yup, that is what I put on.
'bout 40 bucks from Walmart.
Works great! I do however still have the original welded to the trailer and all I need is the crank. Hmm, I wonder if the new jack crank will fit . . . . . . . .
mcrandall
Post by mcrandall »
Thought about putting one on each side by the wheels, then I'd be able to jack the trailer up if I ever had a flat. Hmmmm.
Post by Paul »
Just a thought, Scott, I had the crank fall out of my jack and bought a new one and put it on. When I took the top off the old crank I found it's just a z bent piece of steel rod that goes through a bevel gear. The gear had a set screw to hold it in place on the rod. Could be that a new crank handle would not be all that hard to fabricate.
Here's to making even more work for you :wink:
I may not have gotten all I want out of life but I'm certainly glad I never got what I deserved! - The Denverite
Tranquil Chaos
clair hofmann
Post by clair hofmann »
As well as providing jacking for a flat tire, jacks at each wheel let you take the weight off the springs for storage. They would also help in blocking up the boat off the trailer for putting on bottom paint. Harbor Freight and Tractor Supply sell non-castoring Ag equipment jacks in the 20.00 range. Of course if you had 3 castoring jacks you could move a boat sideways in a garage to get it out of the way.
Clair
mcrandall
Post by mcrandall »
I like the way you think, Clair!
