Mainly, I need help
Post your sail topics here
Mainly, I need help
Post by Paul »
The bottom portion of the main luff is different than the simple mains I have used. There is a line attached to an eyelet that doesn't seem long enough to use as a down haul. One of the sail slugs is attached to this line, but the slug above and below it are attached to the luff.
I'd appreciate help understanding this and its use.
Tranquil Chaos
skyking
Post by skyking »
Is there a chance that this is reef point?
Windward
Post by Windward »
Believe it's called a reef jackline, and it permits the sail to reef smoothly without pinching the cloth and with the new tack pulled all the way down rather than wedged up the track above the other slugs.
Post by Paul »
The Amazing Jeff is correct again! I googled it and here is the explanation:
http://www.blumhorst.com/potterpages/Ph ... -album.htm
So aparently this is not a stock rigging on our C-22's?
Tranquil Chaos
lecker68
Post by lecker68 »
yes he is my original sail on the 26 had the same thing.
