Spring front hatch c22
Beady
Post by Beady »
Does anybody have a source for the spring (hatch prop) for the front hatch on a C22. I broke mine and the front hatch will not stay up without attaching a line to the hatch and tying it off to the mast (pain).
Brian Eady
77 C-22
Sail La Vie
John K
Post by John K »
You'll probably have a rough time finding that spring unless someone here can send you one. Perhaps you could install one of these?
http://www.catalinadirect.com/index.cfm ... entCat=373
1977 C22: Dog House
Chrysler20%26
Post by Chrysler20%26 »
try to fix your spring, my spring broke where it attaches at the bottom. I put some heat to it, so that I could bend it.
Last edited by Chrysler20%26 on Sun Apr 08, 2012 12:04 am, edited 1 time in total.
Beady
Post by Beady »
That is the same place where mine broke. i will give that a try at this point I can't really screw it up because it is already broken.
Brian Eady
77 C-22
Sail La Vie
N41EF
Post by N41EF »
I've slept since then. but I would swear that West Marine has that stuff in their print catalog. I remember seeing thinking crap it's a spring, how could that break?
Now we know.
EDIT: Actually it was bass pro shops. Maybe I've been reading too many catalogs?
http://www.basspro.com/Bass-Pro-Shops-8 ... 003cd6bb75
1979 C22 S/V Client Meeting
N41EF wrote: Maybe I've been reading too many catalogs?
Its a sign of complete assimilation into the Boat Borg you know.. :wink:
Beady
Post by Beady »
Wow thanks the Bass Pro solution looks great, parts for the boat and less than 15 bucks Excellent!!
Brian Eady
77 C-22
Sail La Vie
Post by Paul »
OK, now I need pictures. You guys talked about a spring - and then put (support) as a descriptor. I have supports (which were also broken but found a couple on e-bay) but I don't have a spring. Where does that go and what does it do?
Tranquil Chaos
Chrysler20%26
No photo, but pitcher this in your mind. It takes two one on each side http://www.basspro.com/Bass-Pro-Shops-8 ... 003cd6bb75 that is what the spring looks like when open, to close you just push down on the center of both springs at the same time. P S my broken spring was not hard to fix. Use a torch to heat it, where you wont to bend it
N41EF
Post by N41EF »
My 1979 C22 only has one spring on it, and I don't see where another would be. It's on the STBD side.
mcrandall
Post by mcrandall »
I would love to see a pic of somebody's spring(s) showing where they are mounted.
My hatch just has two rods (one on each side) that run through a small swival sleeve. A knurled nobbed bolt locks them in place.
Nicknick32
Post by Nicknick32 »
Ill post one tomorrow.
John K
Post by John K »
Chrysler20%26 wrote:No photo, but pitcher this in your mind. It takes two one on each side http://www.basspro.com/Bass-Pro-Shops-8 ... 003cd6bb75 that is what the spring looks like when open, to close you just push down on the center of both springs at the same time. P S my broken spring was not hard to fix. Use a torch to heat it, where you wont to bend it
Good find! I didn't realize that this application of the spring was that often used. You learn something new every day.
1977 C22: Dog House
Nicknick32
I hope its not over kill :lol:
Nick....
trev
Post by trev »
Thanks for the pics, I've wondered how that all went together.
I'm kind of curious where the compression post is in your boat?
77 C25
Myasis Dragon
http://www.svmyasisdragon.com
Nicknick32
It in the back of my jeep :P
I took it out to re-finish the wood on both ends an to un the wire inside of it so it does not look sloppy as hell.
mcrandall
Post by mcrandall »
Thanks Nick!
My compression post is currently laying down on the job too!
Chrysler20%26
Thank you for the photos, same set up on my C-26
