Spring front hatch c22
Does anybody have a source for the spring (hatch prop) for the front hatch on a C22. I broke mine and the front hatch will not stay up without attaching a line to the hatch and tying it off to the mast (pain).
Brian Eady
77 C-22
Sail La Vie
77 C-22
Sail La Vie
You'll probably have a rough time finding that spring unless someone here can send you one. Perhaps you could install one of these?
http://www.catalinadirect.com/index.cfm ... entCat=373
1977 C22: Dog House
- Chrysler20%26
try to fix your spring, my spring broke where it attaches at the bottom. I put some heat to it, so that I could bend it.
Last edited by Chrysler20%26 on Sun Apr 08, 2012 12:04 am, edited 1 time in total.
I've slept since then. but I would swear that West Marine has that stuff in their print catalog. I remember seeing thinking crap it's a spring, how could that break?
Now we know.
EDIT: Actually it was bass pro shops. Maybe I've been reading too many catalogs?
http://www.basspro.com/Bass-Pro-Shops-8 ... 003cd6bb75
Now we know.
1979 C22 S/V Client Meeting
- Chrysler20%26
No photo, but pitcher this in your mind. It takes two one on each side http://www.basspro.com/Bass-Pro-Shops-8 ... 003cd6bb75 that is what the spring looks like when open, to close you just push down on the center of both springs at the same time. P S my broken spring was not hard to fix. Use a torch to heat it, where you wont to bend it
I would love to see a pic of somebody's spring(s) showing where they are mounted.
My hatch just has two rods (one on each side) that run through a small swival sleeve. A knurled nobbed bolt locks them in place.
Good find! I didn't realize that this application of the spring was that often used. You learn something new every day.Chrysler20%26 wrote:No photo, but pitcher this in your mind. It takes two one on each side http://www.basspro.com/Bass-Pro-Shops-8 ... 003cd6bb75 that is what the spring looks like when open, to close you just push down on the center of both springs at the same time. P S my broken spring was not hard to fix. Use a torch to heat it, where you wont to bend it
1977 C22: Dog House
Thanks Nick!
My compression post is currently laying down on the job too!
- Chrysler20%26
