UPDATE ON SUNK 26
njerrell
UPDATE ON SUNK 26
Just a quick update on the boat,the trash pump worked well,overtook the leak in no time,when i got in her the breach was right where i thought,the rudder post bent and broke the fitting taking some fiberglass with her,it was about a 3'' tear in the hull,since my new cushions were ruined anyway i cut one up squeezed the water out and stuffed it to slow the leak down,now a sump pump is in the bilge and keeping her up,a friend from the docks went home and got his trailer for his 25-oday and we are going to pull her tommorow,it looks bad but i really dont see anything that cant be overcome,ill keep you guys posted and get some pics this weekend.
njerrell
Njerrell
We had 40 mph winds on False River when that front moved thru last night, a club member's Wellcraft/Starwind got loose, and is sitting the bottom now, so anything you could pass along on how many tubes you used, what pump, the whole process etc might be helpful to him.
If you need to, send the pics to me again and I'll host/post them, etc.
My C26 had vinyl behind the banquettes and a burlap-ish liner everwhere else. I replaced the vinyl at Hancock Fabrics.
Hey, Gus, you're serious ? Sorry, man
