I was lucky enough for the keel cable to only fall down a couple inches inside the clear tube so i was able to pull it up and rescuer it, but I have no idea how to fix the rudder issue with the boat in the water.
Any advice is welcomed
Zac
Didn't think about you trying to keep rudder down while motoring to dock until I read this, duh on my part - Had the same issue once on EE, so I'll add what we did so folks have a couple of options - we took a long line, made a loop in one end, and slipped that over the rudder and pulled the loop tight. Then carried the line forward letting it sink under the boat (there was a wrench for weight involved here), and ran it thru the bow eye, pushed the rudder down with a pole, and took up all the slack at the bow and cleated the line off. Was enough foward/aft tension to keep the rudder down.Zac Penn wrote:Well I ended up with a pretty nice fix so we could get the boat down to the ramp and still use the tiller.
Zac
