2"x3"x1/8" square steel tubing
2"x2"x1/8" square steel tubing
1/4" x 1.25" flat steel
Welded the square tubing together and used the flat steel for a strap to cradle the boat. Total material cost was around $125 at scrap yard, so around $30 per stand not too bad for re-usable stands. They give easy access to underside for keel maintenance, etc. In one pic, you can see once the stands were under her, I lowered the trailer with keel at same time. When keel cleared the trunk, it layed over with a big thud on the trailer. Hooked a cable to the trailer and pulled it keel and all.
close-up with dimensions
From bow with trailer and keel showing
Straps -- second pic shows the heavy foam for padding. The ugly holes were drilled with a stick welder, which isn't exactly known for perfect drilling.
The straps are 1/4" inch steel and not likely to bend, but I put a bolt there anyway.
ready for work
[/img]
