Rub Rail Repair
Special area for the smaller Chryslers - Musketeer, Buccaneer, Mutineer, Man O' War, Pirateer, Daggers, etc.
desert sailor
Rub Rail Repair
Postby desert sailor » Fri May 04, 2018 2:22 pm
Hi, all;
I have a '70s LS16. I was going to install a new rub rail to make it look nicer. Most of the kits I looked at on-line seem to snap over the edge to hold the piece in place. When I started to remove the rail on my boat it appears that the hull and topside are two pieces with a flange at the joint and the rail is somehow stapled through the flange to hold everything together. Does this sound right? Does anyone know how to fix/replace the rub rail? Are rub rails even available anywhere? If I don't replace it and just try to clean it up I would need the aluminum cover that fits over the rail at the stern, port and starboard. Does anyone have a used part I could buy?
Thanks.
Greg
Desert Sailor,
Cochiti Lake, New Mexico
Re: Rub Rail Repair
Postby CaptainScott » Tue May 22, 2018 10:02 am
It might be helpful for folks if you could post pictures of what you are talking about.
Welcome aboard!
desert sailor
Re: Rub Rail Repair
Postby desert sailor » Sun Jun 10, 2018 9:25 pm
Tried to post some pictures of the rub rail and side of the hull. Message says the file is too large. I don't know how to download them here. Suggestions?
Greg
Re: Rub Rail Repair
Postby C22Bob » Mon Jun 11, 2018 6:26 am
Greg,
To keep our server storage cost low, we enforce a 256KB limit for image attachments. Most cameras these days have a default setting of 1MB, so if trying to take something directly off your camera and post here, you're likely going to hit that limit. There are a ton of free photo editors online which are very easy to use. An easy to use website for basic resizing is http://www.simpleimageresizer.com.
I uploaded a 1MB file, chose the 'make image 50% smaller' and got back the file as 258KB.
Full Disclaimer -- Chryslersailors.com is not associated with that web site, and advise you carefully read their privacy policy before uploading files to it. Some of these sites make money obviously through advertisements, but also take ownership of your image for possible sale to stock photo houses.
Also, keep in mind you don't have to attach the file. If the image is already on a website, get the image address and paste into your message using the BBCode [img] image tag ---here's some info on that under our FAQ
http://www.chryslersailors.com/discussion/faq.php?sid=049e3e14f616593124f33c9711ab8101#f3r3
austinbillt
Re: Rub Rail Repair
Postby austinbillt » Mon Jul 16, 2018 12:08 pm
I have a late 1960's LS-13 with he same issue. I have located a custom source for extruding a replacement rub rail (ExactSeal in Indianapolis), and the preliminary estimate is around $5/foot. However, they have minimum of 100 feet, and we all need something just less than 35 feet. If we can find a third person, we should all be able to get to for $175 or less.
Bil Thompson, Austin, TX. 512-461-9230 cell, or bill_thompson@csi.com
austinbillt
Re: Rub Rail Repair
Postby austinbillt » Wed Aug 15, 2018 2:23 pm
I have a late 1960's LS-13 with he same issue. The rail has a slot that accommodates the ridge and is attached using silicone sealant. I have not been able to find a stock source for this rub rail. However, I have located a custom source for extruding a replacement rub rail which is a half oval shape with a slot (ExactSeal in Indianapolis), and the cost is $8/foot plus a $125 set up fee. However, they have minimum of 100 feet, and we all need something just less than 35 feet. If we can find a third person to participate, it will cost just over $300 each.
Return to “DaySailors”
Users browsing this forum: No registered users and 0 guests
