This cable was attached while the sails were up? I like the idea due to my boom being supported by the sail, it does tend to get in the way once in a while?
Is there any of you using this system?
tnc110 wrote:I too use a hook to the backstay...
I have a question as to how/where you keep the gooseneck on the mast...both with the sail up and down. I'm not sure if I'm rigging it right, but I tie a short piece of rope to the eyelet in the sail, go around the front of the mast, down the mast, through the eyelet and back up to the sail. Then i pull the halyard to pull it all tight...is this right or is there an easier way to rig it?
Then when i drop the sail I slide the gooseneck up above the slot in the mast and insert the pin that keeps the gooseneck from sliding down. This all works, but it seems there might be an easier way to do this all...
tnc110 wrote:ok...i see how the mast gate works, but what do i use to put in the mast groove to keep the boom from going all the way down to the bottom of the mast...I assume there is something designed to do the job?
