Spreaders
Zilbub
Spreaders
Post by Zilbub »
There are some homemade spreaders on the mast of my C-22. I was wondering if anyone had a good source for new spreaders including the brackets used to mount them to the mast.
Thanks.
Bhacurly
Post by Bhacurly »
Did you have any luck?
My mounting brackets have been drilled several times, as has the mast. It looks weak and I'm thinking of having a new set welded to the mast. Then remove the spreaders when trailering. Thoughts?
Billy
Zilbub
Spreaders
Post by Zilbub »
I haven't had any real luck other than finding this site: http://www.dwyermast.com/items.asp?cat1 ... 28Round%29
My spreaders are actually in good shape so I might just make sure they won't chafe the lines. Let me know if you find anything else.
Jon
