when i bought my c22 the previous owner was planning on painting the boat and pulled the rub rail rubber out of the rub rail. I dont know how long ago he did this. today i re-sealed the seams behind the rub rail with 5200 and re installed the rubber. problem is that the rubber is about 4-6 inches short now. i guess it shrunk??? how can i stretch it back out....heat?
btw...i tried to soak the rubber and the rail with soap/water and push/pull it back in from one end...it didnt work. however i did succeed by using a rubber mallet to beat it in. start the upper groove by hand and beat the lower groove in...
rub rail rubber shrunk???
mjt
I bought new rub rail that worked well. I don't have the exact part number anymore, but here is a link to the company and the page that has the rail I believe I purchased.
http://tacomarine.com/cat--Semi-Rigid-V ... vinyl.html
If you take an xacto knife and cut off a very thin cross section of your existing rub rail and mail it to them, they can tell you what the closest match they have is....
Mike
Mike
