My C22 mast base was broken where you place the pin when raising the mast. I was going to cast a new one, but my furnace is down right now. So I thought I would fabricate a stainless "horse shoe" to take care of it in the mean time. Link to pictures below. Pay no attention to the date on the pictures- I haven't reset the camera after changing batteries. All this was done today. I used 1/8" 304L stainless that I purchased from Online Metals. I had to rip it to 7/8" on a bandsaw as it was too wide. I drilled 1/8" holes to mark everything and then bent the strap. Bending after the larger holes are drilled would make too sharp a bend at the holes, especially the 11/16". I punched the mast base, drilled and tapped 1/4-20 holes in four places. It is very stout as an assembly and should do the job.
http://community.webshots.com/user/volcanoe42
Fixing a broken mast base
- gregcrawford
Paul the Denverite
Nicely done, thanks for the photo's and the idea should I ever need it.
- gregcrawford
I kind of look at this as a temporary fix (although I may never change it). It took me about an hour and a half to make this strap.
It's been a few years, but I built an electric aluminum melting furnace following Dave Gingery's book and made quite a few aluminum castings. I still have the furnace and the molding sand so when I get around to replacing the burned out electric element, I will cast a couple of new mast bases using modeling clay to fill in the holes on the old one and using it as a plug. The casting sand has a petroleum binder, and reproduces beautifully.
I don't plan on filling in the broken out space at the bottom.
It's been a long time since I did any aluminum casting. It was surprisingly easy with the right sand and equipment, the results were excellent. I tended to take a bit longer making the sand castings then my teacher was happy with but I had very little clean-up on the final casting because the prep time paid off in the end.
