C26 motor... remote or tiller?
My boat came with a remote control, electric start motor as I believe most did. I'm wondering if anyone has experience, good or bad, with tiller control or pull start motors on a C26.
EE originally had a 5hp Merc for power. Everytime I pulled on the starter cord I banged my knuckles on the transom due to the angle of pull and height of motor. Also was a pain to reach over the stern to shift or to adjust the tiller throttle.
With that memory in mind, I love my electric start and remotes !
EE,
That's exactly what I was thinking. Thanks
Tom and Cathy I believe we belong to a few of the same sites.
Yes mine is a little small for the 26 does fine even in rough weather. In the Hudson river which here is narrow so the current moves faster(like a venturi)
and pushes her along at 6.5 kt. My friend has a Bristol 26 with a 9.9 Johnson
and a 4 blade sailboat prop and I keep up with him with a 4 stroke 4 hp
Johnson with a 3 blade prop. as for docking I have to come in slow and before my bow gets near the dock I have to be in reverse as it takes almost 2 boat lengths to get her stopped and as far as pull start I have hit the stern
light cover with my finger a few times and it aint pretty when the cover goes between your finger and finger nail.
lecker68, A 4hp on a 26?? My C20 came with a 5hp 4-stork Honda 26" shaft. ( that now has a burned out impaler) That I am worndering how to fix. I put a bran new Neson 4hp 4-strok 20" saft on the C-20. An I was going out for a sail, the wind was comming from the east, to shor, waves were 2 to 3 feet. So I was headding strat into the wind an waves. Going out of the cut, to the lake. I was barly moving, the prope was cavatating, ( comming out of the water. So when I had rome to come about , I did. I pould the boat an took of the 4hp an put the 9.9 Chrysler on. Better over power than under power. Your 4hp does not cavate ( come out of water ) If my 4hp had a 26" shaft it would do the job (I Think)
Hey Lyle,
What other forums do you frequent?
I'm on a couple of trailer sailor mail lists. Besides here I check into www.sailfar.net, www.conchcruisers.net and www.cruisingworld.com forums on a semi regular basis.
For those taking a look Conch Cruisers seems to be nearing death, but feel free to breath some life back into it.
Chrysler20&26 yes in water that rough it does cavitate and I get out of the creek and get the sails up. I have yet to have my outboard cavitate under sail power and my 26 points well. I have a 9.9 Chrysler up north that will take remote controls but no elect start and it has a problem with recoil.
Tom sailfar and plasticclasic and of course here. I ran 110 power into the boat so I can have light and heat to work during the winter.
