Before I trailer anywhere else I want to add a dedicated rear mast support so I don't have to jury-rig something like we did to get home. I had hoped I could just install a stern rail, level with the bow pulpit, for lowering the mast and for travel. But Banshi tells me that the transom is forward of the balance point on the mast when it is lowered. Does anybody know by how much?
Pics of what works for you?
Stern rail/mast support
- LeatherneckPA
Iron Mike - Semper Fidelis
1978 C-22: Believer
1978 C-22: Believer
Check this setup out.
I have a nice square stock with a roller on it.
The square stock has pins welded to it and the boat has a couple of cathes for the pins. It literally just sets in place.
Yes the balance point is slightly aft of the support.
However my mast is hinged.so it can set there nicely intill I pull the pin on the hinge. As I pull the pin, I simply put on hand on the end of the mast and hold it from flipping backwards. Easy Peezy. Then I simply roll the mast forward past the balance point or until it is where I want it for travel.
Look at the full sized version of the photo near the outboard at the support holding the mast!!
I'll look for better photos. I know I have some SOMEWHERE! LOL!
http://captainscottsailing.com/pictures ... C_1035.JPG
Your browser will resize the photo smaller so you'll need to turn that off to see the full sized photo for details.
PS: you can see this is before we cleaned her up and renamed her after my mom!
- Andiron120
Mine is a C-26 so might be different, but my mast support is barely forward of the balance point when mast is lowered. It takes just a slight push down and forward to engage the mast step hook.
I'll probably modify it to sit just a few inches farther aft, but it works. I also have to raise the roller slightly so the mast will clear our newly installed solar panel on the companionway hatch.
I added a trailer keel roller after the picture, to make moving the mast easier. I have a similar setup without roller on the pulpit to carry the mast.
