Chrysler 22 project update
Jmckamey
Post by Jmckamey »
Hello forum folks, thought I would post a few pics of some of the work I have been into lately. Getting pretty close to being able to go sailing. The second album is a fiberglass repair I did on the stern, where the backstay and stern pulpit brackets are mounted.Just click on all albums to view. Jeff
http://s743.photobucket.com/albums/xx80 ... 022%20pics
Great shots!
Your link did not work so here it is:
http://s743.photobucket.com/albums/xx80 ... ss%20work/
Jmckamey
Post by Jmckamey »
Thanks, I had to go back and fix it. Should be good now. Jeff
That is some pretty good fiberglass work there!
What is the final white coat?
From the photos, looks like you did a fantastic job!
I recommend the forum users look at ALL the photos!!
Jmckamey
Post by Jmckamey »
Hey scott. Thanks! Tried some gel coat but did'nt like the way it turned out. Ended up using epoxy paint. Plan on painting the top sides in a couple of years anyway, It'll match then.
Makes sense and looks great!
I hope to be rebuilding my little 8'er soon and will be looking for final coat finishing ideas then.
My poor little saior has a couple of soft spots in the glass. I'll be grinding or cutting it out and reduing her thus requiring a new finish coat.
Maybe you should come up here and do it for me! LOL!
Jmckamey
Post by Jmckamey »
Alright, went back and added captions again. Hopefully the pics make sense now, and can be helpfull.
Jmckamey
Post by Jmckamey »
Thanks for the comment. As for cutting formica, first use duct tape over the cut line, next cut just a wee bit large, 1/8" or so. Then finish up with a router (with a guide), if you don't have a router, a belt sander will stand in nicely. Hope you find this helpfull. Jeff
Leeway
Post by Leeway »
Jmckamey wrote:Thanks for the comment. As for cutting formica, first use duct tape over the cut line, next cut just a wee bit large, 1/8" or so. Then finish up with a router (with a guide), if you don't have a router, a belt sander will stand in nicely. Hope you find this helpfull. Jeff
Like Alan said. They make special router bits for Formica.
Also, if you do not have a router you can score the line with a special Formica blade for a utility knife after applying duct or painters tape.
Lee Hoeppner
Boat: C-15 Man-o-War
Year: Pre-1973
