New owner (22)/ new member... say HI !!
Posted: Wed Jan 26, 2011 5:21 pm
by Papax3
Hey!
New to boats as a whole, and just bought a Chrysler 22. Honestly in excellent shape; great deal. Main was just way too old, will buy one at "sail warehouse" $475, unless you tell me otherwise. Jib is new. Mast - good. Hull - good, approaching bottom-paint time, but trailered; top decks in great shape (was kept out of sun for most of it's life: NO spider cracking, ever-so-slight crazing at scant "abuse" points). It tended to list to starboard when I put in, and it took a while to realize that the foam in the starboard cockpit seats was holding water. So here's the good news: I evacuated all of the foam in the seats, and the hull remains as hard as a tank. The plywood inbetween seat/ storage was glassed, with zero sign of rot. The plywood-?-floor-underlayment-decking (sub-liner)- also glassed, also zero rot. So if you are wondering about the hull going soft related to "foam problems".... very, very, very unlikely. Up towards the starboard bow seat/area, I'm removing that foam as well... it seems to go underneath the bow storage area though. If you have any information about the extent to which foam was used in these boats I would greatly appreciate any info. I think the seats are the only area where there was foam, and I want to know if it also goes lower than that, directly beneath the flooring sandwiched between inner-liner and hull. I'm thinking it doesn't, so far. Again, my hull was hard as a rock. For those who debate "foam removal", I will say this: in evacuating the foam, the water was mostly held "low"/ gravitationally, but also ANYWHERE the foam touched the fiberglass (much like capillary attraction). I realize now... that probably ANY product coming in contact/ layered next to ANY hull, will likely keep/ wick water, and just hold it there. The first three inches of foam where foam-touches-hull is where the water is held, the center mass was simply dry. If you don't mind work, it wasn't too bad to get rid of, it did carry a good amount of water (probably coming in from the toe-rail) and I think it will likely rid your boat of a resin-y type smell if you remove it... very pungent.
The inner-liner is a sandwich of fiberglass with a honey-comb cardboard core. The cardboard was stable, but suffering water damage: but only on the sitting/ horizontal surface of the seat (where water vapor could rise and permeate). Hull...again... really I'm vulgar impressive... thick hand layed matting and weave: you'll never see them built like this again. The transom (thank God) was made completely of glass. I consider the hull virtually indestructable - exceptions being impact damage, and .... hideous neglect. I appreciate the "round" construction of the top-decks, because I can hear lots of micro-flexing going on when I walk on it, and it tells me that it is built like the inner-liner (fiberglass-honeycomb cardboard-sandwich). The "roundness" will undoubtedly help structural integrity, where a flat top-deck would clearly breakdown in the same amount of time. Next thought centers around my Keel, and guessing it's just time to do it, too. NOTHING else could go wrong with my boat, short of that. I will probably make the metal templates myself... would be nice to know the thicknesses of metal, and the diameter of the rod.
Whew!
I talk too much.
I've heard you guys are incredibly supportive, and I can't wait to make some long-standing friendships here. Happy sailing when tha' weather breaks! Message Posted 01-27-2011.
:wink:
Bill Williams
email: whwthor@yahoo.com
Posted: Wed Jan 26, 2011 6:29 pm
Welcome aboard,
The foam isn't for support so removing it shouldn't cause any structural problems. It was intended as flotation to prevent the boat from sinking if it filled with water. Of coarse if it becomes water logged this defeats the purpose.
Posted: Wed Jan 26, 2011 6:56 pm
by lecker68
Welcome aboard Bill we are a friendly crew and it sounds like you made a great buy.
Posted: Wed Jan 26, 2011 8:11 pm
by mcrandall
Welcome, Bill!
I've cut into my seat on the starboard side to check the reason for my listing--yep, waterlogged foam. Once it thaws this spring, out it comes!
As you'll soon learn, this site is the best!
Cheers!
Posted: Wed Jan 26, 2011 11:52 pm
Welcome aboard ship mate!
Ah your in the right place, I came on the forum as a strait up novice to sailing. I now claim rank amateur status.
As for foam, my belief is it was for flotation in a sinking, not structural as stated above.
Now as for the glassed plywood. I don't have that on my C-22. Plywood yes, not glassed. I think a prior owner did the glassing but I suppose it could be OEM.
As for a new sail, you might want to order that soon well before sailing season when the sail lofts will be real busy.
So where do you hale from? East Coast, West Coast, Mid West, Canada? Toss us a bone, we're always doing stuff together on this forum. :D Can't be helped, we are very social. But take your time if your nervous. We'll grow on you and then you'll hooked. It took me a couple months just to post the first time. Now they can't shut me up. :lol:
Posted: Thu Jan 27, 2011 6:06 am
Welcome aboard Bill!
Glad to see ya here! If my feeble memory serves me correctly, I spoke with you on the phone a while back!
Again, Welcome aboard!
Posted: Thu Jan 27, 2011 6:56 am
by back2class
Great score! Any trailer and outboard for that tiny sum?. I picked one up decent shape recently for $1250 with no trailer, but good outboard and thought I was doing pretty well. Sounds like you got me beat no matter what it comes with...lol
Posted: Thu Jan 27, 2011 7:21 am
by John K
I think the $475 figure was referencing the price of a new main at Sail Warehouse. I'm wanting to order one as well. My bride is not as enthusiastic about it though. :?
Posted: Thu Jan 27, 2011 10:16 am
by Capt. Bondo
Welcome aboard Bill.
I beleave there is foam under the v-birth also, I also have foam in the stern on each side of the fuel locker.
I have a suspicion I have water soaked foam under my starboard settee also when I noticed condensation there last fall.
I like the idea of floation 8)
Posted: Thu Jan 27, 2011 4:30 pm
by Bhacurly
Welcome Bill!
Think the only thing I would wish in my new main would be 2 or even 3 reef points...
Billy
Posted: Thu Jan 27, 2011 5:58 pm
by skyking
Welcome Aboard Bill....
Posted: Fri Jan 28, 2011 10:13 am
by Windward
Bill, welcome to the Chrysler Cult... um, CREW!
Posted: Fri Jan 28, 2011 2:46 pm
I can confirm there is foam under the V-birth, I removed some to add ballast forward to offset the hunk of metal hanging off the transom :) Mine was high and dry in this location.
Posted: Fri Jan 28, 2011 6:07 pm
Funny, when I walk to the bow, when I am solo sailing, The motor/prop comes out of the water. :shock: So I always shut the motor down before going forward when I sail alone.
Now I've lost 30 lbs. since I last sailed the Honu. Maybe I can leave the motor down and idling while I move up to the bow now, and it will still pump water to cool. :lol: So maybe I'll need to add weight to the stern now as I was sail quite level with the motor up and me sitting in the back before the weight loss! :shock:
I'm going to get to a normal weight by July 2011. I'm down 66 lbs from my all time high, which is when I bought the boat in the spring of 2008. See these Chrysler are good for you. :P That's my story and I'm sticking to it. :wink:
Posted: Sat Jan 29, 2011 8:29 am
by Beady
Hey welcome and enjoy. I find this group of guys are really great and full of some great ideas. Everybody on the site loves pictures!!!
Posted: Sun Jan 30, 2011 11:00 am
by mariner
Welcome! you will love the boat and the people that you meet on the board, a great group! post pics we love them!
Posted: Sun Jan 30, 2011 7:20 pm
by astrorad
From one Bill to another...Hi and Welcome....Yes we all love pictures and posting....it really helps keep this place alive...I will be doing plenty of pics/posting come spring when I really get started on my restoration.
Posted: Sun Jan 30, 2011 9:56 pm
by Paul
Yea, Bill, and in the meantime your avitar influenced me to subscribe to Practical Sailor. Got my first 2 copies and enjoy them!
Paul
Posted: Tue Feb 01, 2011 7:43 am
by Jmckamey
Hello and welcome, now that you have removed the wet foam are you going to replace it or use the space for storeage? The subject has come up a couple of times before but have yet to see any pics of the area after foam removal. Would love to see some pics :D
BTW, the keel pin is one inch in Dia. The plates are around 3/16", you'll be able to assertain that dimention when you remove the old ones as they sit in a resessed area.
