Bucc mast partner
onespeed
Bucc mast partner
Post by onespeed »
My new-to-me Chrysler Bucc has a homemade mast partner fabricated by a previous owner. Mine is a high-step Chrysler as opposed to this low-step diagram, but the form and function of the mast partner appears to be the same.
Image[/img]
The Good: It's been sailed several times w/o incident; it's waterproof and durable (cut from Corian-style synthetic counter top material).
The Bad: It's not centered and affects mast plumb and shroud tension, so is likely to negatively impact performance, weather helm and feel.
The Ugly: The thing is ugly, not confidence-inspiring due to ill fit, and it's fastening bolts tend to shift out of the grooves, if you can call the rough cuts that term.
If I end up making a new one, I'd want the stock thickness dimension and a picture of how they're fastened to the deck. It'd be great to get a tracing of an OEM part. Here's one of the current one.
Of course, it'd be fantastic to have a new or used one that is the right fit. I just don't think it wise to monkey around with spar fittings!
Any ideas beyond calling Nickels? They don't list that part on their website, as far as I have found.
All the best,
---Onespeed
Champion's Edition Chrysler Bucc #3508
In the "classic" (campy?) black and gold colorway!
Anybody know what the marketers called it?
Any other Buccs near you?
Maybe you could borrow one and have it copied and fabricated?
Just shooting in the dark for you . . . .
Hopefuly some more ideas will pop up!
There's also a Yahoo group of Bucc owners at
http://groups.yahoo.com/group/Bucc18_Fleet_30/
If no one here has access to an original template they might on that list..
And a class association site at:
http://buccaneer18.org/
Hope that helps !
EE
