I searched and found a killer one that mounts to a rear pulpit, which I don't have. Anyone have a decent plan or drawing, or at least pictures?
Thanks in advance!
The mast support on both of my C-22's have 2 cups just on the outside of the backstay brackets that the support drops into. They look similar to the stanchion mounts. The support is angled toward the center with a flat top and a roller on it.N41EF wrote:There are two black plastic brackets mounted inside the upper lip of the cockpit, is that where the mast support is supposed to go?
My outboard is a 5hp two stoke, weighs about 65 pounds, since I'm already too light on the tongue weight I figured I'd haul it in the back of the rover.
