Plywood walls?
Plywood walls?
Hi All,
My C26 has what appears to be thin luan plywood along the cabin sidewall above the seat-backs going up to the toerail. Is there any reason to remove this to check behind it? What was it covered with from the factory? What have you guys done with it?....fabric re-cover, paint, formica?
blu by you
- sauerleigh
Like the others it sounds like a P.O. addition. If it will come off with out having to use a crowbar, checking behind it maybe a good idea... you never know. What you chose to replace it with, if in fact you take it down is up to you... checking with the first mate first however is a good first move. As a starting point I'll be painting the inside of my C26 project something more elaborate may come further down the road.
Chrysler 26' 1980
Chrysler 26' 1980
My 1980 C-26 does not have plywood either it is like a berber carpet when I remove it I may use a resin and sand smooth and paint.
- thepartydog
Mine was fabric, how does the plywood look? Thinking aloud, you can use steam to bend thin luan. That might solve a issue on the big brother's big boat. Sister in law doesn't like the carpet used in the same area on brother's big boat. That and properly oiled it might look nice on "Ya Never Know".
Darin
"Ya Never Know"
1980 C26
"Ya Never Know"
1980 C26
Plywood walls?
It definitely is factory-installed. I am thinking that it is the backing for the vertically rolled vinyl that was the factory wall covering. I think the PO just pulled off the vinyl and never replaced it. Has anyone else replaced the rolled vinyl? I'm going to be installing new carpet on the floors, so I was thinking of gluing the same carpet there as well. Not a good idea? Thoughts?
- sauerleigh
plywood walls
I have a C26 in which I have removed 2/3 of the fabric covering the bulkheads. What I found was a foam backing that has pretty much disintegrated into power. The fabric comes off very easy and I remove any remaining adhesive and foam with a vacum cleaner. I plan on painting the bulkheads with a sealer called 123. It's a thankless job but will be better and safer when I am done because there won't be any of the powder floating in the air after it is gone.
Sounds typical of the headliner material used in cars. A thin fabric attached to a thin foam layer, which is spray glued to the fiberglass headliner in my Rover. I have a source for headliner fabric and the spray adhesive, though it's not hard to find online. Land Rover Disco's have a very wide headliner because of the huge rear windows.
Using headliner fabric might cut the dust down more than using carpet.
1979 C22 S/V Client Meeting
Bearly
There was no plywood on the cabin side wall, just the fabric with foam backing. This is what I did.
When we did the inside of our boat we used wire brushs on the hull, then metal putte knife to scrape some more of the glue off. Then we mixed 1/2 cup of mr clean to a gallon of water and use sctube brushs and that got most of the glue off. We painted to hull but is was still rought, so then we ended up putting carpet on. the only place we did not put the carpet on was the under side of the stern berth.
http://s935.photobucket.com/home/LakeOr ... entuploads
1979 C-26
Easy Street
~~~_/)~~~
1979 C-26
Easy Street
~~~_/)~~~
