Learn something new every day.
Posted: Mon Apr 16, 2012 11:42 am
I went and paid my dock fees for the boat and cleaned her up a little. I started to screw around with the pop up top. I then discover what the block of metal on the mast was for. It holds the pop up top in place. I had thought the previous owner had installed it and could not find a use or had never seen anything quite like that on a boat before. One of the screws on the support bracket had pulled out and the top seemed very unstable so I just never bothered with it. Using the block on the mast it seems to work fine so I am going to fix the support pole.
Was the piece from the factory and once the supports are in the up position is there another lock that installs on the supports?( I used to have a pop up camper and there were safety supports.
http://www.brianeady.com/Other/Sail-av- ... 39&k=id2Cu
