Rotten wood
Rotten wood
Hi, question for any C20 owners. I've found a lot of rotten plywood which encapsulates the foam flotation in the stern below the cockpit. Anyone have the same issue? How would you recommend dealing with this? This area is very difficult to access and I don't yet know how far the rot extends. Help!!
							Adam
1976 C-20
Milwaukee,WI
						1976 C-20
Milwaukee,WI
Adam that bytes!
The link is to a product that may help. Sounds like a no fun job to take out and replace then reglass!
http://www.systemthree.com/store/pc/Rot-Fix-c39.htm
I've never used this product myself....
Billy
Billy
The 20's are great boats, but notorious top leakers due to a flawed rail design that holds water in. As a former C-20 owner I would make sure what needs to be solid is. eg, the plywood that holds the keel winch, the mast step, the wood that supports the standing rigging, etc. You can easily go way overboard on these 40+ year old boats as far as time and money if your a purest.  The wood supporting the standing rigging on my 20 had been reinforced. The wood that enclosed the flotation material was 1+" thick, moist but intact. I don't know how many years it would have taken to dry them out, but they served the purpose and held the flotation material in place.  I don't know how your boat compares. Here's an interior vid of my old 20 as a reference.
http://youtu.be/ufDeHz3FxfI
I use the KISS'S principal when it comes to old boat repair. Keep It Safe and Simple..... and and Sail 'em! Just my 2 cents worth. Best of luck to you Nunya!
Bruce
Poupon Me!
Ray Twp., MI
- Earnest K. Gann
Poupon Me!
Ray Twp., MI
- Earnest K. Gann
Thanks Bruce!
So yea it's tight in there, but you could get in there and cut out any bad wood, dry it out as best you can... then glass in some new wood.
Goes without saying to stop where the water is getting in, ie sealing the hardware up top. I would imagine the foam is waterlogged too. I know folks with C-22's have cut out there foam for the same reason. Lotta weight in there if it is wet. What you do then is open to debate. Storage is nice, an not sure what flotation could go back in.
Billy
Billy
