For Sale, a 1978 Chrysler 22 foot Sail boat, Trailer, Motor, sails etc.
This is a fixer up looking for a good home.
Boat:
- Hull is good shape and only needs some gel coat work around the mast step.
- The wiring is almost done but needs a fuse panel put in.
- Mast was upgraded to a MUCH heavier one by the original owner. I have rewired the mast and added an anchor light and steaming/deck light.
- Needs a tiller.
Trailer is in good shape, but can use some new wood, and tires only hold air for about 1 or 2 days.
Motor is a Chrysler Sailor 9.9hp with throttle controls in the cockpit.
Boat has a Jib and Main, and a few other sails from another boat that can be made into whatever you want, boat also has an auto tiller, compass, and a powerless knot meter. Blocks and other misc. gear also goes with this boat.
First $900 takes it all
Thank you
DaveB
dbauerle@netexp.com
Please note Chrysler Sail boat in any message so your e-mail does not get trashed with any spam
						For sale 1978 Chrysler 22 in Michigan
Could this be the boat to be cut up
To bad, I did not see this add in time.
