Rudder
Posted: Tue May 21, 2019 3:50 pm
by avidsailor
I have a 22 ft. No Idea how the rudder stays down. I NEED TO REPLACE THE TILLER TOO. TIKI WIKI IS MY PROJECT BOAT. I APPRECIATE SOME PICTURES. HER OLD NAME WAS TUNA
Re: Rudder
Posted: Wed May 22, 2019 9:21 am
Best thing is to go to our documents page and look at the rigging design of the 22. There is a pair of lines on the rudder itself. One to pull the rudder up and the other to pull it down. There is a jam cleat on the tiller handle to hold the line in use. When I replaced these lines on a C22 I used a red and a green line. The red to pull the rudder up, and green to pull it down. No confusion as to which line I wanted to pull. Also adding a small "t" handle on the line makes for easier pulling.
Re: Rudder
Posted: Wed May 22, 2019 2:14 pm
by avidsailor
Thank You
Re: Rudder
Posted: Thu May 23, 2019 4:40 am
by Skipper Dan
Making a new tiller is easy.
Re: Rudder
Posted: Thu May 23, 2019 9:21 am
Very cool!
I love the custom name on it!
Re: Rudder
Posted: Thu May 23, 2019 10:28 am
by Skipper Dan
I wrap the lower part in fiberglass and overdrill the holes and fill them with epoxy. It is the last tiller I will need.
add a tiller cover from left over Sunbrella
Re: Rudder
Posted: Thu May 30, 2019 4:35 am
by Jeff P
I bought a C22 over the weekend. I went to put my outboard on the mount and it looks like the rudder will interfere with the motor when the rudder is raised. Should the motor mount be moved off to one side?
Re: Rudder
Posted: Thu May 30, 2019 10:18 am
Not necessary.
I've had 4 C22's to date and all had center mounts on the motor.
Typically I ran with rudder down fully all the time. When motoring the motor was locked to keep it from turning and I steer with the tiller/rudder.
Never had an issue.
Re: Rudder
Posted: Mon Sep 16, 2019 5:23 pm
by Skipper Dan
Captain Scott, do you know where to get the rudder kits for the 22. Someone keeps asking me and I do not know what to tell them.
Re: Rudder
Posted: Tue Mar 02, 2021 3:06 am
by Stevenstreets
Ruddercraft.com you will find all the parts you need.
