1- the deck flex when the rig is under tension(the drop board does not fit as well as at "rest")
2- I dont like the hull-deck joint and dont want to fiberglass it
So here's what I came up with, pretty heavy-duty dont you think? it's made of 1,5" x 3/16 stainless flatbar, I dont like the exterior look as the bar is not parallel to the deck (it is parallel to water line) but will try to "camouflage" this by removing the painted line in the portion and write the name of the boat there.
BTW it was pretty time consuming and I would not especially recommend doing it for this reason (took 3-4 days).
Altough the fitting appears to be all the same, each is different to fit the angle of the hull... nothing's square nor flat on a boat...
before polishing
