rudder assembly C26
				mainsheetmike
rudder assembly C26
Looking for rudder assembly and post for C26. have non retractable shoal draft rudder, want retractable rudder
				mainsheetmike
c26 rudder
Thanks for the reply, I just purchased the boat and haven't tried the rudder yot.  Not sure what the difference in a retractable and non is as far as holding in a blow. Does the rudder often come up to hit the prop? New cleats help? This rudder is shallower than the keel trunk,so if grounded, it will be clear.  How well is your rudder with a lot of weather helm? or down wind in a blow, does it seem to hold the boat? Thanks, Mike
				njerrell
Hello,just thought id throw my 2 cents in on the rudder issue,my c26 has the stock retractable rudder and while its effective its not the greatest design in my opinion,the rudder kicks up by default instead of down which is a bit of a problem if using the outboard.It seems the rudders have never really worked the way they are designed with the control lines,you usually have to use an oar or something to help start the rudder into the down position.Like i said its just my opinion but i have thought of trying a shoal draft rudder and doing away with the stock all together.
Nathan
						Nathan
				mainsheetmike
c26 Rudder
Thanks for the info on the problems with the rudder coming up.  Mabey I will try the rudder as is to see how well it works. I'll post the results as soon as the ice melts at Blue Mesa lake near Gunnison co.  thanks, Mike
						C-26 Rudder Head Assmbly
I also need a rudderhead and yoke for a C-26 swing keel.. I have a retractable rudder with aluminum shaft  dimens of 1.050 O.D.
If anyone knows where i can find a rudderhead and yoke let me know.
OR...A good Diagram or schematic of it would work. May have to make one.
W Jones
Wake Forest NC
C-26 Canadian Mist
W Jones
Wake Forest NC
C-26 Canadian Mist
