Center board gasket replacement
turfdog
Post by turfdog »
The center board gasket on the Mutineer I have needs replacing and looking for suggestions as to what material to use and where I can get it.
Mario G
Post by Mario G »
Can you post a picture of the old one? There are automotive seals of all kinds .
Seen some Coronado C15 types use the garage door bottom seal material. I think the factory replacement material for those boats is sailcloth over mylar.
turfdog
Centerboard gasket
Post by turfdog »
There are two different types of gasket rubber on it now and it looks like garage door material but the mylar material sounds like a better idea. Any thoughts on where I can get this?
Guster
Post by Guster »
I replaced mine with this, (3" wide)
http://www.apsltd.com/c-100-SlotStrip-C ... erial.aspx
And followed Ray's instructions here,
http://www.mutineer15.org/Rey_s_Upgrades.html
Just open the .pdf CB gasket replacement.
Good luck,
1976 C-22
The thread I was looking at mentioned Ullman Sails as a source, but you probably could Google a better source that would be less costly.
If you haven't found it here's an article on replacing that gasket
http://www.mutineer15.org/files/37061448.pdf
turfdog
Centerboard gasket
Post by turfdog »
Thanks to all for the help. The link for the material is exactly what I was looking for. This forum is the best. Will have to post a picture once I am done.
Greg
