Rudder
avidsailor
Rudder
I have a 22 ft. No Idea how the rudder stays down. I NEED TO REPLACE THE TILLER TOO. TIKI WIKI IS MY PROJECT BOAT. I APPRECIATE SOME PICTURES. HER OLD NAME WAS TUNA
Re: Rudder
Best thing is to go to our documents page and look at the rigging design of the 22. There is a pair of lines on the rudder itself. One to pull the rudder up and the other to pull it down. There is a jam cleat on the tiller handle to hold the line in use. When I replaced these lines on a C22 I used a red and a green line. The red to pull the rudder up, and green to pull it down. No confusion as to which line I wanted to pull. Also adding a small "t" handle on the line makes for easier pulling.
- Skipper Dan
Re: Rudder
Making a new tiller is easy.
Re: Rudder
Very cool!
I love the custom name on it!
- Skipper Dan
Re: Rudder
I wrap the lower part in fiberglass and overdrill the holes and fill them with epoxy. It is the last tiller I will need.
add a tiller cover from left over Sunbrella
Re: Rudder
I bought a C22 over the weekend. I went to put my outboard on the mount and it looks like the rudder will interfere with the motor when the rudder is raised. Should the motor mount be moved off to one side?
Re: Rudder
Not necessary.
I've had 4 C22's to date and all had center mounts on the motor.
Typically I ran with rudder down fully all the time. When motoring the motor was locked to keep it from turning and I steer with the tiller/rudder.
Never had an issue.
Never had an issue.
- Skipper Dan
Re: Rudder
Captain Scott, do you know where to get the rudder kits for the 22. Someone keeps asking me and I do not know what to tell them.
Stevenstreets
Re: Rudder
Ruddercraft.com you will find all the parts you need.
