wet sanding and waxing
Mario G
Post by Mario G »
it started by wet sanding a few marks out of the hull gel coat and enden doing the whole hull. It looks great about like a new boat, not to mention I'm sure it will move thru the water better.
Gus
Post by Gus »
That was me last week. I did the whole boat and waxed it using 3M polisher. I don't know if it'll make the boat move faster, but it makes it easier to clean the water grime.
NYCSAILOR
Post by NYCSAILOR »
let me know your process .... I am very unhappy with the reslt of my 3M polisher/restotrer/wax job... two days on the hull with the power buffer and not really much to show for it .. oh, my back hurts.
C-26, Fixed Keel # 343
tnc110
Post by tnc110 »
If your boat is fairly chalky you will have to wet sand it prior to buffing/polishing. (make sure you keep it wet at all times) If you are just doing from the rub rail down you should be able to knock out even the worst job in a solid day....unless you are going to be happy with nothing short of perfect....
She looks AWESOME!
Sorry the 3m materials did not work for you NCSAILOR.
I've used them a lot and have had good results.
NYCSAILOR
Post by NYCSAILOR »
Ok, I had the PRO at the boatyard examine my topsides, he said they are fine, not chalky at all and in good shape just dirty and dull, he said to just wash it good , sold me marine "spray nine"cleaner , that is what they were using in the yard, and I did research on line and went to another boat yard and they said they use the one-step.. and polish...
went back to my boat and the pro refinisher there did sow me some pro tips on how to use the buffer and the 3M product, went at it did one side per day and it seemed to be shinier when I was done -- it was VERY dull, but not noticiable now that she is in her slip and nothing I could boast about on the forum, so maybe I have to do more... trying to avoid a paint job here but it may be inevitable. Yard pro said don't need paint and it should polish up nice....
Gus
Post by Gus »
I wash the boat, and let it dry. Apply 3M polisher and let it dry. After that I just buff it. I usually do it once or twice a year.
Gus
NYCSAILOR wrote:let me know your process .... I am very unhappy with the reslt of my 3M polisher/restotrer/wax job... two days on the hull with the power buffer and not really much to show for it .. oh, my back hurts.
NYCSAILOR
Post by NYCSAILOR »
thanks..
gonna try and hit my topsides with spray 9 cleanner scrub it up and then go over it with the powerwasher, then try and polish the cockpit area.. maybe this weekend. inspired to also and and varnish my cabin ladder, tiller and hatch boards.... maybe hatch slider trim too... might get ambitious and order new "hatch slider teflon plastic" while I am at it.. I will do a search..
Gus
Post by Gus »
The main thing its to let the wax dry. The bottle says do a little bit, apply, do another bit, bla bla. I just wax the whole boat, let it dry, then I buff it by hand. I had one of those cheapo rotary buffers, but it took me forever. I can do the whole hull in a couple of hours.
Gus
NYC - hatch slider material:
this thread
viewtopic.php?t=877&highlight=mcmaster+carr
